Fuse
location | Designation in Wiring Diagram | Nominal
Value | Function/Component | Termi
nal |
SC1 | Fuse 1 (On Fuse Panel C) -SC1- | 10 A | -Windshield Defogger Relay -J47- | 30 |
SC2 | Fuse 2 (On Fuse Panel C) -SC2- | 10 A | Steering column electronics control module -J527- | 30 |
SC3 | Not used | - | - | - |
SC4 | Fuse 4 (on fuse panel C) -SC4- | 10 A
7.5 A | Vehicle electrical system control module -J519-
Alarm horn -H12- | 30 |
SC5 | Fuse 5 (on fuse panel C) -SC5- | 7.5 A | Data bus on board diagnostic interface -J533-
Remote Start System Relay -J471- 1) 2) | 30 |
SC6 | Fuse 6 (on fuse panel C) -SC6- | 7.5 A | Selector lever -E313-
Ignition Switch Key Lock Solenoid -N376- | 30 |
SC7 | Fuse 7 (on fuse panel C) -SC7- | 10 A | Heater and A/C controls -EX21-
Rear window defogger relay -J9-
A/C clutch relay -J44- | 30 |
SC8 | Fuse 8 (on fuse panel C) -SC8- | 7.5 A | Diagnostic connection -U31-
Electromechanical parking brake button -E538-
Humidity, rain and light recognition sensor -G823-
Rain/light recognition sensor -G397-
Rotary light switch -EX1-
Parking brake button -EX12-
Instrument panel contour illumination lamp 1 -L243-
Instrument panel contour illumination lamp 2 -L244-
Anti-theft alarm system sensor -G578-
Instrument panel contour illumination lamp 3 -L245-
Passenger Side Door Ambient Lighting Lamp -W87-
Driver Side Door Ambient Lighting Lamp -W86-
Storage compartment illumination bulb -L120- | 30 |
SC9 | Fuse 9 (on fuse panel C) -SC9- | 7.5 A | Steering column electronics control module -J527-
Ignition/starter switch -D | 30 |
SC10 | Fuse 10 (on fuse panel C) -SC10- | 7.5 A | Front information display control head -J685- | 30 |
SC11 | Fuse 11 (on fuse panel C) -SC11- | 40 A | Vehicle electrical system control module -J519- | 30 |
SC12 | Fuse 12 (on fuse panel C) -SC12- | 20 A | Information electronics control module 1 -J794-
Navigation system control module -J856- | 30 |
SC13 | Not used | - | - | - |
SC14 | Fuse 14 (on fuse panel C) -SC14- | 40 A | Fresh air blower control module -J126- | 30 |
SC15 | Fuse 15 (on fuse panel C) -SC15- | 10 A | Electronic steering column lock control module -J764- | 30 |
SC16 | Fuse 16 (on fuse panel C) -SC16- | 7.5 A | USB charging socket 1 -U37-
Storage compartment with cell phone interface -R265-
USB connection 1 -U41- | 30 |
SC17 | Fuse 17 (on fuse panel C) -SC17- | 7.5 A | Instrument cluster -KX2-
Control module for emergency call module and communication unit -J949- | 30 |
SC18 | Fuse 18 (on fuse panel C) -SC18- | 7.5 A | Rearview camera -R189- | 30 |
SC19 | Fuse 19 (on fuse panel C) -SC19- | 7.5 A | Access/start system interface -J965- | 30 |
SC20 | Fuse 20 (on fuse panel C) -SC20- | 15 A | Vacuum pump relay -J318- | - |
SC21 | Not used | - | - | |
SC22 | Not used | - | - | - |
SC23 | Fuse 23 (on fuse panel C) -SC23- | 20 A | Power sunroof control module -J245- | 30 |
SC24 | Fuse 24 (on fuse panel C) -SC24- | 40 A | Vehicle electrical system control module -J519- | 30 |
SC25 | Fuse 25 (on fuse panel C) -SC25- | 30 A | Driver Door Control Module -J386-
Left rear window regulator motor -V26- | 30
30 |
SC26 | Fuse 26 (on fuse panel C) -SC26- | 30 A | Vehicle electrical system control module -J519- | 30 |
SC27 | Fuse 27 (on fuse panel C) -SC27- | 30 A | Vehicle electrical system control module -J519- | 30 |
SC28 | Not used | - | - | - |
SC29 | Fuse 29 (on fuse panel C) -SC29- | 5 A | Refrigerant circuit pressure sensor -G805- | 15 |
SC30 | Fuse 30 (on fuse panel C) -SC30- | 10 A | Remote Start System Relay -J471- 1) 2) | 30 |
SC31 | Not used | - | - | - |
SC32 | Fuse 32 (on fuse panel C) -SC32- | 10 A | Blind spot detection control module -J1086-
Blind spot detection control module 2 -J1087-
Parking aid control module -J446-
Driver assistance systems front camera -R242-
Distance regulation control module -J428- | 15 |
SC33 | Fuse 33 (on fuse panel C) -SC33- | 7.5 A | Airbag control module -J234-
Front passenger airbag -disabled- indicator lamp -K145-
Passenger occupant detection system control module -J706- | 15 |
SC34 | Fuse 34 (on fuse panel C) -SC34- | 7.5 A
10 A3 | Refrigerant Circuit Pressure Sensor -G805- 4)
Center console switch module 1 -EX23-
Interior rearview mirror -EX5-
Back-up lamp switch -F4-
Structure borne sound control module -J869-
Air quality sensor -G238-
Rear seat heating control module -J786-
Center console switch module 2 -EX30-
Sockets relay -J807-
Parking brake button -EX12- | 15 |
SC35 | Fuse 35 (on fuse panel C) -SC35- | 7.5 A | Diagnostic connection -U31- | 15 |
SC36 | Fuse 36 (on fuse panel C) -SC36- | - | - | - |
SC37 | Fuse 37 (on fuse panel C) -SC37- | - | - | - |
SC38 | Not used | - | - | - |
SC39 | Fuse 39 (on fuse panel C) -SC39- | 30 A | Front Passenger’s Door Control Module -J387-
Right rear window regulator motor -V27- | 30 |
SC40
5) 6) | Fuse 40 (on fuse panel C) -SC40- | 20 A | 12 V socket 2 -U18-
USB Charging Socket Fuse -S356-
Remote start system fuse 1 -S250- | 155) /
306) |
SC41 | Not used | - | - | - |
SC42 | Fuse 42 (on fuse panel C) -SC42- | 40 A | Vehicle electrical system control module -J519- | 30 |
SC43 | Fuse 43 (on fuse panel C) -SC43- | 30 A | Digital sound system control module -J525- | 30 |
SC44 | Not used | - | - | - |
SC45 | Fuse 45 (on fuse panel C) -SC45- | 15 A | Left front seat adjustment control head -EX33-
Driver seat lumbar support adjustment switch -E176-
Left front seat cushion fan 1 -V514-
Left front seat backrest fan 1 -V512-
Driver seat adjustment control module -J810- | 30 |
SC46 | Fuse 46 (on fuse panel C) -SC46- | 7.5 A- | -USB Charging Socket 1 -U37- | 30 |
SC47 | Not used | - | - | - |
SC48 | Not used | - | - | - |
SC49 | Fuse 49 (on fuse panel C) -SC49- | 7.5
A7)
5 A 7) | Starter relay 1 -J906-
Starter relay 2 -J907-
Clutch position sensor -G476-
Remote Start System Relay -J471- 2)
USB Charging Socket Fuse -S356- | 15 |
SC50 | Not used | - | - | - |
SC51 | Fuse 51 (on fuse panel C) -SC51- | 25 A | Rear seat heating control module -J786-
Front passenger power seat adjustment circuit breaker 1 -S46- | 30 |
SC52 | Fuse 52 (on fuse panel C) -SC52- | 15 A | Electronic damping control module -J250- | - |
SC53 | Fuse 53 (on fuse panel C) -SC53- | 30 A | Rear window defogger relay -J9- | 15 |
